door hinge pin removal 31 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2006, 09:29 PM
Hi; does anyone know where I can get a hinge pin removal tool for the doors. I've seen them but cant recall where. thanks. twin-pipes
Old 03-29-2006, 09:38 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I just use a punch and a hammer.
Old 03-29-2006, 09:40 PM
thanks but I tried that they are really in there. I dont want to screw up the door adjustment.
Bob Drake has them in his catalog.........I have one and it works great.
As a Old Ford guy and a Moderator, I want to WELCOME YOU ... to Hotrodders.com
Old 03-29-2006, 09:45 PM
Heat the hinge with an oxy/acetylene torch then quench the pin, it should tap right out after that. Fit a new pin and use a good grease when you reassemble it. Drilling a grease hole on the inside opening of the hinge and adding a spiral grease groove to the new pin will make it greasable and last forever. Bob
Old 03-29-2006, 09:49 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Mac's have them but a lot more expensive than a punch and hammer. Here is a link to the search page. Type in door hinge pin removal tool.
http://www.parts123.com/parts123/yb....hPage~cadeffcx
Either way make sure you soak them good with penetrating oil first. Good luck.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 03-29-2006, 10:12 PM
thanks every one I will check out the sites you listed.
31 ford coupe solid roof markh55 Body - Exterior 8 04-02-2013 12:47 AM
lowering a top on a 31 ford coupe rov,nmechanic Body - Exterior 2 04-01-2003 10:21 AM
31 ford 5 window coupe body and frame krzycat Body - Exterior 0 12-14-2002 08:00 AM
31 FORD COUPE SUICIDE DOORS dcurhotrod Body - Exterior 2 11-03-2002 08:56 PM
Ford Race Engine BarbWire Engine 7 10-18-2002 12:38 PM
