door hinges - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 04:13 PM
door hinges
can some one tell me how to take off the actual hinge on my 1992 GMC sonoma
Old 09-02-2006, 04:22 PM
adtkart@aol.com
If you can't see any bolts, they are likely welded on. The doors are removed and installed by taking out the hinge pins. If the hinge is loose and allowing the door to drop down, it is likely that it needs hinge pins and bushings. This is a common problem with GM trucks like that.
Aaron
