Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - door jam prep for epoxy
Old 04-11-2005, 05:37 PM
myfamiliacc myfamiliacc is offline
Have Gun, Will Paint
One wet coat could be good enough but I would go with 2 wet coats.
You can do your body work over the epoxy just scuff it.
Sence you do have bodywork it's best to go with a high build primer. 2 to 3 coats of that.
Block sand it all smooth
contenue with a sealer or stright paint.
