door jambs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2008, 08:01 PM
shadowismydogsname's Avatar
door jambs
if the whole vehicle is to bare metal and two coats of epoxy primer is applyed over it...and when it comes time to spray the primer over it all,does the door jambs get the same amount as the rest?whill the door jambs need to be sanded?
Old 11-08-2008, 08:51 PM
Only if you want it to stick. I used to top coat over sanded Dupont Colar Epoxy primer after sanding it. It is just harder to sand than ureathane primer.
Old 11-08-2008, 09:17 PM
what i meant ask is how many coats of primer over the epoxy whill the door jambs need? i have seen them put 1 coat over the whole vehicle then hang the doors and put another few coats with the doors shut...then block sand it all...
Old 11-08-2008, 09:27 PM
I was confused? You can top coat or spray sealer over the epoxy if you can sand it smooth without sanding throught it. There are several people on this that use a epoxy primer that can be used for bare metal, surfacer and primer. A couple of coats of primer surfacer should be all you need unless they are real rough.
Old 11-08-2008, 09:28 PM
SPI is the brand they are using.
Old 11-09-2008, 03:50 AM
so if the whole vehicle including the door jambs get 3 coats of primer and the panels are all block sanded down..that means i have to sand the door jambs..right?...but i wont need a block will i?...i could just do it with my hand until its smooth..
Old 11-09-2008, 08:07 AM
One the small flat spots use a cut down paint stick and the small flat curves a ruibber hose. Save yourself some time use one coat in the jambs. Samething with the body prime and block the metal worked areas first as they will need more than the straight panels. No sense with lot of high dollar primer surfacer on the flooor and not on the car.
Old 11-09-2008, 01:59 PM
ok so one coat shuld be enough in the door jambs...but if(for some reason) i sand through i can touch up that spot..what grit paper do u think wuld be good just to get one coat of primer smooth?i was thinking about 1000?
Old 11-10-2008, 05:43 AM
Don't pile up primer surfacer in your jambs as there's no reason for this extra material unless you have some defects to fill and sand out.
Old 11-10-2008, 07:48 AM
I use my detail gun to touch up sand throughs. Final sand paper grit depends on the paint you are going to use. The most common are Ureathane 800-1000 and Acrylic enamel 400-500.
Old 11-10-2008, 01:43 PM
i will be using bc/cc with a gloss dulling aditive in the clear.
Old 11-10-2008, 06:04 PM
Last journal entry: More on the Cobra Engine
Don't you consider the Door jams to be Part of the CAR?? Sure they should get treated just as you would any other part of the body. That means the same cleaning, de-waxing, sanding and priming.
