door latch repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2003, 04:39 AM
Post door latch repair
I am a newbie at door repair and this bulletin board. I have a 1970 Chevy El Camino. The door latch or the drivers side sticks and the passenger side wont work at all. I tryed to unscrew it latch but she will not budge. Please help.
Old 05-14-2003, 04:28 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post
What exactly is sticking? Have you tried some WD40?
Alan Horvath
54 Chevy Pickup
Old 05-14-2003, 05:11 PM
Post
Thanks for the reply. The 4 screws that hold the latch in place will not budge. I have tried WD40 and a hammer. I figured i would take the latch out, clean and oil it , if it was in good shape, reinstall it. But first have have to get it out. Is there some easy way to get those screws loosened
Old 05-14-2003, 07:28 PM
horvath's Avatar
Post
Wow ... sounds like a real bear!
WD40 is all I can think of ... it spreads when you spray it and usually gets the job done. I'd try spraying from the other side - by removing the door panel.
Alan
Old 05-14-2003, 08:06 PM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
Post
push comes to shove, drill them out. It's ugly, but I've encountered it more than once disassembling my truck
Old 05-15-2003, 05:13 PM
redcamaro4spd's Avatar
drive it like you hate it
Post
I know in my 2nd gen. camaro, my doors would stick and the prob was that they had painted the latch mechanism and it would stick, some wd-40 fixed that no prob. And for the bolts, try PB Blaster, it is a penetrating oil you can get at most auto stores and the stuff is strong as you won't believe.
