Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - door panel
Thread: door panel
Old 01-15-2006, 03:14 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
Should be able to just go around the edges and pry the clips out on both sides and the bottom, might be a couple of screws in the arm rest to remove also, then lift up and out and it should come off. If you do not have power windows you may need a window handle clip removal tool.
