-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   door panel (http://www.hotrodders.com/forum/door-panel-78873.html)
burninrubbah617 01-15-2006 12:48 PM
door panel
how do I remove the interior drivers side door panel without damaging anything?
swvalcon 01-15-2006 12:53 PM
what year and what kind of car?
Henry Highrise 01-15-2006 01:18 PM
The same way you remove the passenger side...J/K :D What year and model car are you working on?
burninrubbah617 01-15-2006 01:58 PM
its an 87 chevy caprice
WakBordr7387 01-15-2006 02:10 PM
Should just be able to take out a few screws and just pop it off carefully. Doe it have manual windows and locks? With the windows you just have to pop off the handle crank by taking the clip off the back of it with a small screwdriver.
Brad
Henry Highrise 01-15-2006 02:14 PM
Should be able to just go around the edges and pry the clips out on both sides and the bottom, might be a couple of screws in the arm rest to remove also, then lift up and out and it should come off. If you do not have power windows you may need a window handle clip removal tool.
