door panel - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2006, 12:48 PM
door panel
how do I remove the interior drivers side door panel without damaging anything?
Old 01-15-2006, 12:53 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
what year and what kind of car?
Old 01-15-2006, 01:18 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The same way you remove the passenger side...J/K What year and model car are you working on?
Old 01-15-2006, 01:58 PM
its an 87 chevy caprice
Old 01-15-2006, 02:10 PM
WakBordr7387's Avatar
Gone fishin'
Last journal entry: blah.......again
Wiki Edits: 2
Should just be able to take out a few screws and just pop it off carefully. Doe it have manual windows and locks? With the windows you just have to pop off the handle crank by taking the clip off the back of it with a small screwdriver.
Brad
Old 01-15-2006, 02:14 PM
Lost in the 60's
Wiki Edits: 4
Should be able to just go around the edges and pry the clips out on both sides and the bottom, might be a couple of screws in the arm rest to remove also, then lift up and out and it should come off. If you do not have power windows you may need a window handle clip removal tool.
