door panel attachment - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-13-2009, 07:02 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Originally Posted by dbinnc
I think they are installed wrong. They are installed from the back of the masonite. so the teeth are facing away from the door. I had never used them before and was going off another DIY I had seen. That explains a lot and I should have caught that.
Only problem I see with that is then the flange would show through the tweed then since they are not totally flush. Well lesson learned on that one. What can I do to remedy this w/o ripping the tweed off?
Derek
Vince is right, you are pretty well screwed on this one. You would have to cover the t-nut flanges with a layer of something and then put on your tweed so the flanges don't telegraph through.
  #17 (permalink)
Old 03-16-2009, 07:30 PM
are the 10780 clips what they call frogleg clips?
I've been trying to source some, but auveco won't reply back wth a dealer close to me (edmonton, alberta, canada).
I would like to get them in quantities greater than 4/pkg.
anyone have any leads?
thanks for any help.
terry
  #18 (permalink)
Old 03-16-2009, 07:51 PM
Not sure what clips you need. But I've used these guys before and got very good service.
http://www.allensfasteners.com/
  #19 (permalink)
Old 03-16-2009, 08:05 PM
good place here too
http://www.yourautotrim.com/clips.html
  #20 (permalink)
thanks for the info wanabe and dbinnc.
they both have what I'm after.
I'd prefer to deal in canada but I'll give them a call anyway.
terry
  #21 (permalink)
Old 03-16-2009, 08:09 PM
Wiki Edits: 22
They're called offset clips. You can get them at this web site:
CLICK HERE
Swapping 3rd Members, different pinion attachment BIGSKY Transmission - Rearend 6 08-13-2007 11:48 PM
attachment question for the `puter savy Mackie Hotrodders Site Suggestions and Help 2 03-25-2007 10:13 AM
stud welder attachment crownver Garage - Tools 2 03-04-2006 09:25 PM
Fender attachment ? HHStang Body - Exterior 8 02-06-2006 08:43 PM
rad fan attachment? 34Plymouth Engine 5 02-17-2002 03:05 PM
