Door panel cracked. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2005, 10:47 AM
CdnSoldier's Avatar
New Member
Door panel cracked.
Hello
Another question. My door panels are cracked, are word like to fix them. Anyone know what glue would work. I was down to a Canadian Tire ( wife works there) and NAPA. And they both didn't have any glue for ABS Plastic. My plan is to glue up the crack then fiberglass over for strength, made a clip holder. For some reason, Ford forgot the spot the the plastic clips go into. On the some 92-96 Aerostar door panels. They crack.
And will I have to strip the old vinyl of to recover it? Yes,I could buy new at 300$ Cdn each or at the wreckers at 50-100$ if I can find good ones. but can buy glue and new auto vinyl for 40$.
Old 03-31-2005, 11:25 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
You should be able to get ABS pipe cement at most any hardware store if not try an RV or mobile home supply. I am creating a complete interior for my 1925 from ABS sheet.
Starter cracked for 2nd time Help Please... leastbay Engine 3 12-18-2004 12:33 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
cracked block jtdchevy Engine 35 02-08-2004 11:53 PM
400 cracked steam holes 6speedwagon Engine 8 10-19-2003 07:28 AM
cracked intake juveteach Engine 4 06-18-2003 08:15 AM
