Hotrodders Bulletin Board > Tech Help> Interior
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 03-19-2004, 10:20 PM
swain66 swain66 is offline
New Member
Question door panel help.
I just got door panels for my 66 impala from year one.
they came with the material glued to the panel but not
wrapped. and the top 5 inches or so of the panel is not there
but there is extra material fo it.
I dont have my original door panels to cut that peice off.
what should I do???
  #2
Old 03-19-2004, 11:19 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Like it or not you are going to have to get some of those metal panels! 65 or 66 should work and if I remember correctly the parts are the same on the like years Buick, Olds, Pontiac.
Old 07-13-2004, 09:49 PM
Mr.Upholster Mr.Upholster is offline
New Member
Door Panels
The stuff you need is called water proof panel board....I have it in 2 x 4 sheets...Just cut it off and splice it to the other board.... How to splice?? get a piece of panel board about 3 inches wide get some good waterproof contact glue and overlap the splice board about 1 1/2 inches on each board and presto......but stop about 2 inches from the edges because the thickness will show there.... Use a heavy piece of cotton Duct or canvas for the edges I have videos on all this stuff .....check out my web site ***
Old 09-17-2004, 02:25 PM
cgwhite's Avatar
cgwhite cgwhite is offline
Don't know if you are still working on this but I just saw it and thought I would comment. You need to see about returning those to Year One and getting a set of pre-assembled panels, they come with the top rail already installed, as well as with the inner windowfelt attached. Cost a little more than the ones you have, but, if you have to have the top rail its worth it. The problem with trying to use door panel board is the curve at the top of the panel where it rolls over to the window.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
