We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 02-18-2004, 12:45 AM
Streetrodfan Streetrodfan is offline
Door panel Question
I have read many post on here about what people use for the backing on door panels, kick panels, quarter panels, And is it correct to assume that it really depends on what each individual likes to use or comfortable with? I'm sure there's and arguement as to what is the "best" but I see paneling, wafer board, plastic, and such being talked about. Okay enough for now. Have a good day, Red
Old 02-18-2004, 06:45 PM
kristkustoms's Avatar
kristkustoms kristkustoms is offline
First name...............Shawn
There really isnt a right or wrong door panel board. What ever you find that works well for you. We (Krist Kustoms) like plastic. I believe Shannon likes 1/8" wood. I would recommend staying away from the black "upholstery board" though. That stuff warps REALLY easy.
Old 02-19-2004, 09:00 AM
Hot Rod Up Hot Rod Up is offline
Custom User Text:
Yea, I use 1/8 wood. I only use the black Board where I need to curve in the back corners.
Old 02-19-2004, 09:02 AM
Custom User Text:
Old 02-19-2004, 07:23 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
How do you form those compound curves in the rear corners of the interior?
Vince
Old 02-19-2004, 07:37 PM
astroracer astroracer is offline
STUPID is as STUPID does...
astroracer's barnstar
Wiki editor
Last wiki edit: Crankshaft Coalition Wiki
Nice work Shannon, very well done. If I may ask a question?
I see the 1/8th inch paneling you use for the door panels. What do you do to keep them from absorbing moisture when water gets inside the door? A plastic sheet barrier?
Mark
Old 02-19-2004, 08:59 PM
Custom User Text:
Mark
I worry more about the water getting on the back side of the leather than I do the board give'n problems. I tape up all of the edges of the leather with gule and clear tape. Then I put a sheet of plastic on back of the hole panel. Even if you use the ABS plastic sheets to make door panels you still need to tape up the edge of the leather. It only took one time for a trunk getting messed up to learn that!!!
Not my work just wanted to show you the leather drinking the water!!
"302/Z28" I use the Black panel upholstery Board in the back corners. I bends real easy one way. the other way it dose not want to bend. I'll use 5 or 6 boards, Foam and make it look like one (useing wood and the black board).
Here's a pic while working on a corner.
Old 02-20-2004, 04:54 AM
Wiki editor
Yikes... That just kind of makes your heart sink doesn't it?
Thanks for the reply.
Mark
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
