Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - door panels are a ****** !!
Old 02-01-2013, 09:55 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
I'm sorry, it doesn't make a bit of difference what fabric you want to use, it is the glue and how you use it that makes the difference. Thicker fabric makes the lines you push it into softer and less distinct. You should know that ahead of time and compensate. You can do many things to help. You can sew the lines in, you can use thicker closed cell foam to get more definition etc.etc. etc.
