Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - door panels
Thread: door panels
Old 03-17-2013, 01:19 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Originally Posted by sportcoupe View Post
After reading the post I went out a bought a sheet of Sintra at the local sign shop for $40. Is it best to add a padding of some sort under the final covering first? What works best? It doesn't have to be thick maybe 1/8" to 1/4". Also i need carpet for the floors and trunk area black any ideas what durable and cheap. SC
Yes, put some kind of padding over the Sintra and under the fabric. You can use anything you want to pad the panel, but you would generally use closed cell foam (brand name Volara) which is very firm. It comes in 1/8" and 1/4". Most auto upholstery supply stores have black closed loop automotive carpet or black trunk lining at a reasonable price. Here's one place: Trunklining
