door panels on 28 ford roadster - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2013, 06:48 AM
having trouble making some for the car.
do you trace inside of door and cut them out, if i do this they are to tight to open and close.
also how would i do the sides from doors back and the across the horse collar around back
i plan on using 1/8 hard board but that adds more problems as i can not staple to it what glue would i use been using this stuff called 77 adhesive thanks any help would be welcome oh using pre pleated black vinyl
Old 06-22-2013, 07:36 AM
BOBCRMAN@aol.com's Avatar
Steel or glass car?
Old 06-22-2013, 08:23 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Do not use 1/8" hardboard, you need something flexible like 1/8" (3MM) thick PVC foamboard. Brand names are Komatex, Sintra, CelTec, and Palight. You can get them from a sheet plastic supplier or a sign shop. This is also called expanded PVC or closed cell PVC. The door panels should be slightly less than the perimeter of the door. If that still gives you trouble, make them smaller. Do not use 3M 77 or 74 aerosol glue, it does not work. You need HHR (high heat resistant) top and trim contact adhesive. As far as what to do with the area behind the doors and seat, you will have to post a picture so I can see what we're talking about.
Old 06-22-2013, 08:51 AM
Last journal entry: Getting Started with Upholstery
If you are going to do this yourself, I highly recommend buying and watching the Sid Chavers upholstery DVD's. They are an excellent introduction to the exact things you are asking about.
Old 06-22-2013, 12:17 PM
panels
ok will look into pvc sheets but dont have alot of luck finding stuff like that is wisconsin. where wood I look for the glue you mentioned
Old 06-22-2013, 03:43 PM
Wiki Edits: 22
I live in Wisconsin, and I can find it lots of places. Here's just one place: Badger Plastic & Supply, Inc. (Plover, Wisconsin). Go to your local sign shop, they will have it or can get it.
As far as the glue goes, here is a place on line: Performance Hi-Temp Trim Spray Adhesive Performance is a good glue, even if it is an aerosol, and the proice is reasonable.
Old 06-25-2013, 06:14 AM
Thanks Dan Got boards and panels cut was able to order glue and pleated vinyl so I hope by the weekend I can get started. I do have the panels cut and ready ( I think) thanks for all your help
29 ford roadster door latches hoffy Hotrodding Basics 1 12-29-2011 05:26 PM
Making '27 roadster 1/4 panels from scratch. evintho Body - Exterior 9 08-30-2011 08:27 PM
52 FORD F-1 Door Panels ed keeley Interior 2 11-14-2008 05:32 AM
56 Ford Pick Up Lower Door Patch Panels rkissin1 Hotrodding Basics 1 07-13-2006 06:18 PM
How do you layer panels on door panels genr8rs Interior 6 04-05-2006 07:24 PM
