Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Door panels. Need a little advice
Old 01-02-2010, 04:44 PM
troyhoot troyhoot is offline
Last journal entry: more work
Yes stainless on bottom layer. Then top layer cut out with rounded corners. Last pic is of the top panel with the marker outlining my cut out plan. Some lines are over the cut. I was drawing it out to try and picture things..
That was my concern. If the large hole cut out would cause any trouble. Glad it should work. I havent cut that large hole yet.
Wasnt sure which would be better 1/8 or 1/4 foam. Think im going to order 1/8" and try it.
Ok that should cover me. Just need to cut the large holes. Order my foam and Fabric.
Im about 3 hours from your auto trim. I work for MS state. Just on other side of state. Might need to make a trip to the college so I can just drive up there
Thank you for taking the time to reply Dan. I appreciate it.
