door pins on blazer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2007, 09:04 PM
door pins on blazer
I have a 96 blazer that i need to change pins and bushings. The problem is the person that had it before me never changed them and kept using the door and it wore the hole too big for the bushings. The dealer says they dont make oversize bushings for these and i cant find any that fit the whole snug. Is there anything i can do to get this bushing to stay in there tight? Is it possible to tach the bushing in there i cant think of any other way to do it? Thanks to anyone that may have a suggestion.
Old 05-11-2007, 11:39 PM
BLAZERMAN's Avatar
I have replaced mine twice since I have had it (20 years) I have just went and bought the entire set, hinges and pins that way I know it will fit right and open how it is supposed to.
Old 05-12-2007, 12:17 AM
I think those are weld on hinges. Rick, you could weld the hole up a little then grind it out. But honestly, I have put a small "Half moon" piece of the old bushing in then the new bushing and that worked well.
By the way, here is a "Tip of the day" dealing with these hinges..click here........
Old 05-12-2007, 08:55 AM
Thnaks martinsr. they are weld on hinges i will try tp put half the old bushing in there. If that dont work i'll weld up the hole and drill it. Thats exactly what i wanted to hear. Thanks
Old 05-12-2007, 09:10 AM
Hold on now, you DO NOT want to MIG weld up those holes and drill new. The MIG weld is (depending on wire used) usually MUCH harder than the surrounding metal. Getting a drill to go thru it is one thing, getting a drill to go thru it when you can't get a good shot at it do to the obstructions around a welded on hinge is another thing!
Just put some weld on the side of the hole and then open it back up to round with a burr cutter on a die grinder, or a file.
And look at the striker area, if this door has been hanging for a while it is likely there is some cracks around the stricker area because it has had the crap beat out of it. Also, look at the latch and striker well, many times they need to be replaced because of the before mentioned beating of crap.
Old 05-12-2007, 09:13 AM
Oh, and by the way, don't even THINK of replacing those hinges with the new bolt on ones from GM. That is without a doubt the biggest screwed up mess GM ever thought of!
I have never did the Blazer but I replaced the hinges on a full size pickup once. HOLY CRAP that was one of the worse jobs I have ever done in my life! They give you about four hours to do each hinge! I thought "This is going to be a money maker"
WRONG it is a cluster %#*& of unworldly proportions! Don't even THINK about it. Just repair what you have and go on with life.
Old 05-12-2007, 09:18 AM
Thanks martinsr i will try to just fill in around the whole a little and file it. Yea your right the striker is also a problem but i may still be able to get that working properly without replacing its not as bad as it could be. I dont know why people dont change pins and bushings right away instead of using the door till it almost falls off. Thanks you have been a big help.
96 blazer fuel pump ricksautorestoration Engine 15 06-07-2009 03:16 PM
engine swap in a s10 blazer bill bennett Introduce Yourself 4 05-12-2006 11:47 PM
98 Blazer Shifting Hard After Long Trip Ghetto Jet Transmission - Rearend 5 06-28-2005 09:41 PM
Silverado Blazer 305 Project william27103 Suspension - Brakes - Steering 1 10-18-2004 05:16 PM
1996 4 door s-10 blazer mural/pattern help ChrisMiddleron Body - Exterior 0 12-14-2003 01:34 AM
