door post - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 11:03 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
door post
The 48 dodge I'am working on has some door post issues. Someone has brased a couple holes shut and has been repaired at the bottom with a little rust. Think I can get by with epoxy over brass then fill. I will build a new lower panel and weld in. May build a new rocker panel side to.
ID:	64877   Click image for larger version
ID:	64878   Click image for larger version
Old 04-21-2012, 11:06 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sounds like you have it handled...
Sam
Old 04-21-2012, 11:10 AM
The problem with the brazing is the flux, it's basically an acid. Acid and paint don't mix, and in that brass that is there IS some flux, it is what is attaching it to the metal after all.
If it is ground flat, right at the very edge there is still some flux that can come out. So sealing it off good is the trick, and epoxy primer would be the best for that.
And of course on the inside if it can't be epoxy primed and seam sealed or something a cavity wax is needed to help with sealing it off.
How can I remove 2 door post trim from the post and door frame? 1964 Oldsmobile 442 Body - Exterior 1 07-17-2011 04:41 PM
66chevelle 2 door post ahwheelnut Introduce Yourself 2 07-22-2009 04:55 PM
55 chevy 2 door post dahoggs55 Interior 2 04-28-2006 04:29 PM
'66-2 door post 66BelAir Introduce Yourself 2 01-27-2006 05:49 PM
55 2 Door Post 55fourdoorhotrod Introduce Yourself 1 10-18-2004 06:51 PM
