door screws or bolts?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2005, 04:40 PM
DARK SIDE's Avatar
I took the doors of my 52 buick but I stripped the bolts that look like big machine screws The head is a phillips screwdriver pattern. I can't find replacments so I'm looking for something with an allen head design but no luck. Any ideas??
Old 11-29-2005, 04:43 PM
poncho62's Avatar
Wiki Edits: 5
The Allen head bolts are quite common....any industrial supplier can get them.
Old 11-29-2005, 05:37 PM
46chevyfleetline's Avatar
Last journal entry: A few more
Dark Side; check out FASTENALL. If its not in stock they can get it.
Old 11-29-2005, 06:36 PM
DARK SIDE's Avatar
door screw or bolt
I know that the allen head bolts are common but any place I go I can't get the right size. The heads too big and the threads too small or vise a versa. What is this fastenall. Is it a store? If so where are they located?.
Old 11-29-2005, 06:49 PM
poncho62's Avatar
Wiki Edits: 5
You may have to rethread the tapping plates and recountersink the hinges to fit the bolts that you are able to get.
Old 11-29-2005, 06:58 PM
Hey Darkside; Fastenal
U9-10, 94 Dunkirk Rd.
St. Catherines
984-6965
Take a sample in. Should chase the threads on the post. If that doesnt work let me know how many you need. I know where there is a 52. Was supposed to go pick it up but just havn't had time. It's pretty rough but I might be able to salvage the hinge bolts. Cheers!!!
Old 11-30-2005, 02:49 PM
DARK SIDE's Avatar
bolts
Thax 46 for the info. I'll let you know how I made out and if I need the bolts.
Old 11-30-2005, 09:36 PM
302 Z28's Avatar
You might also try McMaster Carr They have a gazillion bolts and screws.
http://www.mcmaster.com
Vince
Old 12-01-2005, 03:02 PM
DARK SIDE's Avatar
screws
Thax. I'll take a look.
Old 12-01-2005, 03:06 PM
Those phillips headed hinge screws are a real PITA, the last one I worked on with them was a 66 chevy II, what a design flaw IMO. Good luck with it-I hope you get some good allen head style ones to replace them. Torx is another option.
Old 12-01-2005, 09:21 PM
DARK SIDE's Avatar
screws
Ya. They made a big mistake when they put those in. I'm leaning towards retaping the plates and going with a bigger thread and a allen head. Either way it aint going to be fun. thax.
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 09:14 AM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 08:29 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 10:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
Door Alignment Ron M Body - Exterior 2 08-21-2004 02:43 AM
