door seals? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2011, 11:39 PM
door seals?
How hard is it to find and replace the factory door seals? Would I be better off buying a universal kit and just going that route?
Old 12-15-2011, 04:20 AM
deadbodyman's Avatar
Wiki Edits: 11
It depends on what kind of vehicle it is yjey sange from very easy to extreamly hard....Universals are always a last resort...
Old 12-15-2011, 05:47 AM
door seal
Its a 77 Pontiac Trans Am, I will have plenty of time and would prefer to go factory seals. I also need to learn how to adjust the hinges. the driver side door doesnt shut well unless slammed very hard and its not b/c the seals obviously.. Any help or advice you could provide would be amazing. Though it will be at least two weeks before I can post photos or even work on it. Its has to be shipped to my town.
Old 12-15-2011, 07:25 AM
Wiki Edits: 11
OK ,.....Well thats an easy one if I remember right ,the door seal snaps into the door and has a couple screws at the ends....soft seal or steel rubber has some pretty good ones...dont try the universal seals at all....You'll also need the seals that contact the window when its up ...even easier but they get glued in...I think if not they just press in the groove You may also need the 1/4 glass seal...none of the seals are very hard to replace....
AS far as adjusting the doors goes they may need a little tweeking but the main problem would be the pins and bushings need to be replaced, those are heavy doors and it a common problem, an ez job for a pro but a bit tough for a newbie and if the paint is nice theres a good chance you'll mess up the paint on the door and the fender its only a 100.00 job so I;d concider having a pro do it ,but if your handy it can be done if your take all the necessary precautions and listen carefully.If your going to paint it anyway then you can do it without much trouble at all.....
Do the pins and bushings first then adjust the doors and the seals come last...
Old 12-15-2011, 09:57 PM
info
Really great info man I really appreciate you passing that on. I will definitely attack the problem in that order. The only thing that sucks is I just found out unless I pay to ship it I wont get it in my town until the end of FEB...
Old 12-16-2011, 09:08 PM
Wiki Edits: 11
It seams like years huh ...I had to wait a week one time ...all I did was worry. let us know when your ready.... I kinda like doing them with the door on the car, removing one then replace it then get the next one it save a lot of adjusting time and its easier when your doing it alone
Old 12-16-2011, 09:43 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Check these guys out: http://www.steelerubber.com/
they have been known to have some good quality pieces.
4. gen Camaro door seals _BANDIT_ Body - Exterior 2 08-28-2011 06:22 PM
New door seals and now...... black66 Interior 3 04-21-2006 09:08 PM
Soften New Door Seals x711 Body - Exterior 4 04-01-2006 05:20 PM
Door Window seals 68chevytrkr Body - Exterior 1 03-17-2006 08:24 AM
door seals elkay65 Body - Exterior 4 12-05-2003 05:50 PM
