Door Sill Plates and Custom Carpet - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2005, 07:02 AM
I'm finding lots of links for preformed carpets and how to install them, but nothing on how to make your own carpet and install it. I am also curious if anyone has some good recommendations for a donor door sill plate (to hide the carpet) for a 30/40s pickup. My truck came with nothing to hide the edges and hoping there is something out there that wouldnt' look tacky. I don't want to just screw down some plates of aluminum, but don't know enough about past cars to know what would look nice. Thanks for the help.
Old 06-30-2005, 01:54 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
i would think it would be a totally custom experience
ive heard of cutting and hand sewing the carpet to custom fit
as far as the kick plate you could use diamond plate maybe w/ a emblem and some engraving
good luck ill be interested to see what others will post too
sr66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 06-30-2005, 04:13 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
Could use some Body by Fischer plates of of GM's. I think they might come in various sizes and I bet one of those should fit, or cut up a nasty one and find some nicer ones for the finished piece.
Old 07-01-2005, 07:09 AM
ckucia's Avatar
Can't help with the carpet, although if you find some sites, I'd be interested in hearing about them. There are a lot of sites that sell carpet that you can use, but I wouldn't know how to sew it.
On the sillplates...
I think your best bet is to hit a junkyard and see what's available. My suggestion would be to look for a 60's or 70's big car with 2-doors. The sill plates are very long and metal. Even if they're scratched/dinged, you might be able to paint them or possibly restore the thin metal easily.
Another alternative would be a more modern care with plastic sill plates. Those are a little easier to customize, I'd guess. If you can find one off a four-door truck (I have a 2000 Sierra four door - the doors swing in a "suicide" fashion so the sillplate is very long) that would be good.
Reason I'm suggesting a long one is that you can proably cut off the two ends and make it fit whatever opening you have. Typically, the sill plates are pretty homogeneous in the middle - its just the ends and lenghts that are customized to the vehicle.
Cadillac made some long-door FWD two-doors in the 80's and 90's. You could also try those - Eldorados and Coupe DeVilles. Ditto the FS RWD Caddy's from the late 80's - they made a two-door up until the mid/late 80's in the FS body. Also might look at the last model of Riviera if you can find one. Might also try full-size trucks.
Worse case, if you find one that you like, but can't find it in good condition, you can always use that knowledge to look for nicer ones on e-bay.
Old 07-02-2005, 03:22 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
How about 1" wide 1/8th" thick aluminum strips from Lowes? I was looking at some earlier this afternoon for my truck. They had lengths from 2' to 8'. Cheap. A little Mother's polish and it should look really good. Maybe use some button head bolts to hold it down.
Old 07-04-2005, 06:59 PM
Interiors by Shannon's Avatar
Hey, I'm just the interior guy
I go to the hardware store and buy the long strips like you would put in your home. I cut the fit them to the car with a pair of tin snips. I then cover the with leather ( vinyl will work also ).
Old 07-04-2005, 08:20 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Man, that ^^^^ looks good!
as far as the premolded carpets, they have heated vacuum molds/presses that form them.
Old 07-04-2005, 10:21 PM
1982 SS's Avatar
Flamethrower
Wow, never thought of that...
I like that idea, I'll stash that one away for future use.
Dump plates dstodd1020 Introduce Yourself 1 10-31-2004 05:30 AM
Sill Plates Jammer Hotrodders' Lounge 2 06-21-2002 06:08 PM
