Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Door Skin Patch Panel Install Question
Old 06-12-2012, 06:03 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
First you start with the outer skin get it fitted with the lips folded at a 90 degree angle , use a couple drill screws to hold it in place ,they'll also help you remove and replace it in the same spot every time...Once the outer skin is set in place you can remove the inner piece and know exactly where it goes according to the outterskin thats already in place...When you have the inner all welded in you remove the outter skin and and work the back side of the inner you just welded in,then get it epoxied then epoxy the outter skins backside and put it on with the screws (I like using a flanged lap joint so it wont warp plus you need it when you use screws...fold the skin over with the skinning hammer or a cheap body hammer that you ground one side straight so it will skin better (but not near as good as a skinning hammer) and the dolly then weld up the seam...I use plug welds every two inches and then weld the seam all the way across one spot weld at a time...
ID:	66013   Click image for larger version
