Door Solenoid wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2008, 06:37 PM
A/G WILLYS's Avatar
I just installed a set of 45 lb. door solenoids and wondering if someone could help me on how to wire the relay? The only diagrams i have found are to wire these with a remote push button I'm am just going to use 2 momentary switches, I am using a Bosch 30 amp relay and I have included some photos of the relays and solenoids. Thanks Dave
Name:	Copy of pins1.jpg
ID:	34728   Click image for larger version
Old 12-02-2008, 07:45 PM
A/G WILLYS's Avatar
Just found this diagram can I use the lower diagram in the picture, it seems like you need less wires?
Name:	Copy of circuits.jpg
Old 12-02-2008, 08:26 PM
Last journal entry: More on the Cobra Engine
OK, let's start with the Relay...86 and 85 is the relay power. so you would attach a hot wire to 86 and the ground wire to 85, this would power the relay when the power was on. making the relay change states, or turn on. These are the terminals where you would attach your door switch.
30 is always the main battery power, for what ever the relay controls, in your case this terminal would come from the battery or fuse panel. 87 and 87A are the NO or NC terminals. These are the contacts that change state, so what ever your controlling, your door solenoid, the leads for these solenoids would attach here. on the NO contacts, that means the contacts are normally open, and when you push the door switch, they energize the relay and the relay contact closes and energizes the 87 or 87A contact, which will energise the door solenoid and hopefully open the door. The door solenoid has two leads, the black would be the hot wire and terminate on the 87 terminal of the relay, the white lead is grounded. Good Luck.
Old 12-03-2008, 08:22 AM
302 Z28's Avatar
Here is the web site you need, many combinations available.
Vince
EZ wiring project zipfactor Electrical 3 05-21-2006 03:55 PM
Alternator Wiring question 65Stanger Electrical 8 04-29-2006 02:28 AM
Wiring with fiberglass wbmusarra Electrical 1 11-13-2003 05:18 AM
Wiring harness from scratch, fuse values norcal02 Electrical 3 09-16-2003 11:03 AM
Need Wiring Diagram for 71 Nova sonicse Electrical 5 01-24-2003 12:24 PM
