door stops - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2012, 06:26 PM
door stops
I am missing the door stops (to stop the door from opening too wide and bending hinges)on my 51 chev 2 door. I have no idea what to make for them. I have not been able to find them in any antque or rodder site.Need some ideas on this. I am a accomplished fabricator. Thanks...
Old 02-03-2012, 06:35 PM
Dimwit
Last journal entry: S10 fabrication (cont'd)
Door stop
Is there a vertical roller in the door post? I've had a 51 four door and a 50 two door over the years. I think they had a roller bearing mounted vertically in the door post and a 1-inch wide bar with a U-shaped end attached to the door. If the roller is there, you might be able to fab the stop from some 1/8 flat stock.
Old 02-06-2012, 09:02 AM
Low n' 51ow's Avatar
It's slow, not to low.....yet.
Last journal entry: 1951 Styleline DeLuxe
51 chevy, are you missing all of the mounting hardware or just the strap? I can send some pics of the mounts in the door jamb and the door, however I'm missing the strap piece as well. (I think it's called the check link??) I'll also take a look at my shop manual and see if it has a picture/description of it when I get home tonight.
Old 02-06-2012, 09:48 AM
1971BB427's Avatar
Might try your local big truck wrecking yard. A lot of the newer semi truck doors used a similar stop.
Rear end bump stops Hwyhogg Suspension - Brakes - Steering 3 11-12-2010 06:31 PM
bump stops helrazr3 Suspension - Brakes - Steering 0 06-17-2007 10:35 AM
Where to buy hood bumper stops? MC68 Body - Exterior 2 07-11-2006 10:21 AM
Piston TDC stops how do they work???? christopher406 Engine 3 04-10-2003 04:12 AM
Car Just Stops Running zeeman19 Engine 3 07-14-2002 04:08 AM
