Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - door upholstery question (re vacuum formed doors)
Old 01-21-2005, 11:22 PM
mmartin1872 mmartin1872 is offline
Last journal entry: Surprise Rust in The Trunk
thanks for the link I wasn't sure if the vinyl would conform to that many curves.. is it ok to use that glue, to glue vinyl to vinyl though (wow what a tongue twister)? because that stuff that you said was plastic is actually vinyl that was vacuumed to the foam. with a cardboard type backing. i guess worst that will happen is it doesnt work and i cut all the old stuff off with a knife/razor blade and lay down new foam and vinyl, then possibly inlay a tbird logo or something to make the panel not so flat
