We're winning the case!
Hotrodders Bulletin Board > Tech Help > Interior
  #1
Old 01-04-2003, 08:01 AM
coupe101 coupe101 is offline
Post Door window channels
How do you radius stainless beaded window channel without crimping? Frustated!
Old 01-04-2003, 10:32 AM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Post
Insert solder wire into the rolled bead and then bend. You can also use <a href="http://www.canadametals.com/pdf/cerro_bending.pdf" target="_blank">cerrobend</a> or it's equivalent like woods metal and then heat to water boiling temps and melt it out later. You could also use stainless wire and leave it in there?
The best way is to use a beading roller and then roll the bend you want. Most sheet metal shops will have a tool like this.
Outlawed tunes from outlawed pipes
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
