door window regulator rollers on a 1969 pontiac firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2007, 09:45 AM
hi i have a 1969 pntiac firebird that im working on. both of the door windows wont come up the regulator rollers are worn out does any body knows how to remove the rollers from the window regulator.
Old 11-24-2007, 12:17 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Hi: I'm going to move this thread to General Rodding Tech. You'll get better answers there.
Dan
Old 11-24-2007, 12:43 PM
powerrodsmike's Avatar
Wiki Edits: 161
I don't know about the Firebird specifically, but the others I've done were riveted in. Drill out the rivet from the arm side, and remove the roller.
Most of the time , the new rollers you get from places like Classic industries will have a new rivet. If they don't, you can use a shoulder bolt. You can re use the rivet if you can weld it back in from the backside, but be quick when you cool the weld with your water bottle , or you'll melt the roller.
For cars that don't have replacements available, I have had to make up new rollers out of Delrin, and install them with shoulder bolts.
Later, mikey
BE different....ACT normal.
trying to put a chevy 350 in a 1969 pontiac le mans 54chevy22 Engine 15 09-10-2014 05:27 PM
OHC 6 pontiac into 1979 firebird? Larry Hagman's Liver Engine 4 03-14-2006 10:34 PM
Engine Swap 1987 Pontiac Firebird V6 to V8 bccsrc Engine 12 01-15-2006 06:01 PM
20" wheels on 1969 firebird 69BiRd Body - Exterior 14 09-26-2005 07:18 PM
87 pontiac firebird chevyelc81 Engine 3 04-15-2002 09:47 PM
