doors on a 1949 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2012, 02:54 PM
can someone tell me why my doors sticks out at the bottom on my 49 pickup. it is flush with the cab (front and back) all the way down to about 4-6" from the bottom. any suggestions please help here are some pics that might help with an answer thanks
ID:	62092   Click image for larger version
ID:	62093   Click image for larger version
ID:	62094   Click image for larger version
ID:	62095   Click image for larger version
Old 01-23-2012, 11:51 AM
In another thread, Martin said you may have patch panels that were installed too far in. That may be true. Also, I'd check the condition of the flange around the lower part of your door. Sometimes rust can develop between the layers which can cause swelling. The lower six inches of your door skin my be pushed out because of this or some other reason.
If it isn't rusted, some judicious massaging with a 2x4 and a large hammer might move the flange in enough to satisfy you. If you try this, remember you're only trying to move the outer 3/4-1" of the panel. And, if it doesn't move, don't keep beating on it. You can only turn the flange in if it is out farther than it should be. You can't reshape the door's inner structure this way.
Another thing to remember is, these trucks didn't have perfectly fitting panels when they were new. A lot of what we do when we restore is "blueprinting". Making it the way the designers intended. You might not want to get into that much work.
Old 01-23-2012, 01:06 PM
The inners structure on these doors is VERY strong there, and it comes out right to the edge of the door so there will be NO Bending them like that. I mean, ZERO, there is no way you can "massage" that edge in unless it was just a tiny amount.
The patch panels are in too far, that I am betting on. First of though just to set the record straight, those doors fit like crap from the factory and often stick out at the bottom. But this of course is way more than usual and I still suspect the patch panels.
This truck had someone working on it who put way too much faith in repro parts. A LOT of fitting has to be done with these repro parts before primer or paint should be put on them. And that is where you are at I believe, ready to put a LOT of work into them and re-bondo and re-prime- and likely re-jamb them. Such is life.
Old 01-26-2012, 06:13 PM
doors 49 chevy
i looked at the patch panels real close and they seem to be correct. they fit right up against the door pillar just like they should.can the bottom hinge cause this problem. i shure hope someone can help me with this
Old 01-26-2012, 07:15 PM
shine's Avatar
SPI Thug
Last journal entry: some progress
need a pic of the whole door. looks like the door needs to come up. from what i see it is low front and back. and brian is right. forget bending the door.
Old 01-26-2012, 10:14 PM
You may be right there Shine! Without seeing the rest I am not thinking that it could very well be low and raising it would close that gap up, very good.
Old 01-29-2012, 02:30 PM
Door
One trick body men use is put a block of wood at the top of the door and push in at the bottom to try spring it or kinda twist it to fit the opening. Be carefull not to push to for from the edge of door or you will have more problems. Works well on new cars not so good on old trucks if you cant get enough movement get out the air chisel and mig.
Old 01-29-2012, 10:02 PM
After more discussion in a PM we have determined that the patch panels were installed wrong and the doors can not be aligned to work with the body wrong as it is.
Old 01-30-2012, 05:56 AM
shine's Avatar
SPI Thug
too bad. i would build up the area with evercoat 870 and let it go.
Old 01-31-2012, 04:10 AM
what is 870 will that take care of it. did u see the picture tbrown8338
Old 01-31-2012, 07:54 AM
http://www.amazon.com/Fibreglass-Eve.../dp/B000P72HF4
He's joking, I assume.
If you were going to fill it something like Everglass would be what you would use in my opinion. But maybe Shine wasn't joking and he will explain.
Old 01-31-2012, 09:06 AM
shine's Avatar
SPI Thug
the 870 is an excellent product for this. unless your into cutting the corners and redoing it . a little bit of build would hide the problem. i've seen it used on many vettes to correct gaps. 1/4 to 3/8 is not a big risk here. but it is the only filler i would use for this. forget the dynajunk . are we building a hotrod or a show piece
it is possible to cut the inner door and maybe pull it in some. would have to ponder on it a while to decide how to attack it.
Old 01-31-2012, 04:51 PM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
Having had similar issues on my 54 you may be able to solve part of this problem by adjusting the lower hinge. This is WAG as I have not seen pics of how the door fits at the top.
Have the hinges been rebuilt? If not then I would first replace the hinge pin in both the top and bottom. Without tight hinges any further fitment issues will be fruitless.
Once the hinges are tight, hang the door and heat the exposed area of the bottom hinge strap until it is red. Then place a 1/2 thick board between the door and the cab at the top of the door and close it. Applying firm pressure on the bottom corner and providing some upward force will convince the hinge to move.
This may take several attempts to get satisfactory results but it does also look like the lower cowl panel is installed too far inboard.
If the hinge adjustment gets most of the problem solved I would slice the cowl panel with a cut-off wheel and weld it back in place so the rest of the problem is solved.
Old 01-31-2012, 06:47 PM
yes the hinge pin are good no play at all, but i guess the bottom hinge could be bent some how. the door closes nice and smooth but just stick out at the bottom front and back. here is a couple of photos that might help you to help me. do you have any photo of your hood i am having problems with it also. please help all you can. thanks
ID:	62467   Click image for larger version
ID:	62468   Click image for larger version
ID:	62469   Click image for larger version
ID:	62470   Click image for larger version
Old 01-31-2012, 07:07 PM
here is picture of my hood do you think i can get it any closer or is that about it.
ID:	62472   Click image for larger version
ID:	62473   Click image for larger version
ID:	62474   Click image for larger version
ID:	62475   Click image for larger version
doors and hood on my 1949 chevy pickup tbrown8338 Body - Exterior 18 01-19-2012 11:12 PM
1949 chevy pickup doors tbrown8338 Body - Exterior 1 01-10-2012 06:46 PM
adjusting the hood and doors on my 1949 chevy pickup tbrown8338 Body - Exterior 8 12-04-2011 11:46 PM
1949 chevy pickup cruiser 49 chevy Introduce Yourself 5 03-19-2007 09:03 AM
1949 chevy pickup sumdaymyownshop General Rodding Tech 3 02-14-2005 08:20 AM
