Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - dorman 49241 & 49242 switch wiring
Old 06-18-2012, 06:55 PM
62restomod 62restomod is offline
bought Dorman pwr window switches(chrome square) for my coupe project, 1 single button switch for the trunk (5 pin and 1 two button for the pwr windows). I bought AC Delco sockets and pigtails for the switches. Each pigtail has 12 ga. wires all the same color. I ohmed out the single switch and thought I had it correct but promptly fried both the switch and connector when I tried it.
Does anyone have a schematic showing the hot/ground/motor connections for the double (6 pin switch)? The pin orientation is:
O O O O
O O
The pin location looks correct as I type but when I preview the post the bottom 2 are out of position. The lower posts are direct below the corner posts on the top row.
The 4 pins on the top row all have continuity between them when the switch is in the normal (at rest) position.
Thanks
Bud
In case anyone needs them the ACD part #s for the pigtails are PT188 and PT 254.
