dorman 49241 & 49242 switch wiring
bought Dorman pwr window switches(chrome square) for my coupe project, 1 single button switch for the trunk (5 pin and 1 two button for the pwr windows). I bought AC Delco sockets and pigtails for the switches. Each pigtail has 12 ga. wires all the same color. I ohmed out the single switch and thought I had it correct but promptly fried both the switch and connector when I tried it.
Does anyone have a schematic showing the hot/ground/motor connections for the double (6 pin switch)? The pin orientation is: O O O O O O The pin location looks correct as I type but when I preview the post the bottom 2 are out of position. The lower posts are direct below the corner posts on the top row. The 4 pins on the top row all have continuity between them when the switch is in the normal (at rest) position. Thanks Bud In case anyone needs them the ACD part #s for the pigtails are PT188 and PT 254. |
1 Attachment(s)
Does it look like this?
yes,that looks like the same switch
1 Attachment(s)
The attached schematic should help when you OHM the switch.
vicrod |
1 Attachment(s)
http://www.dormanproducts.com/images...01-016-002.JPG http://www.dormanproducts.com/images...01-016-001.JPG
#49241 http://www.dormanproducts.com/images...01-017-001.JPG http://www.dormanproducts.com/images...01-017-002.JPG #49242 I used 1983 Chevy C10 pu (which used these switches) as a basis, and found the wiring diagram for you ... see attached. |
1 Attachment(s)
My translation of the wire dia
Thanks for the schematics guys, VERY helpful
Bud |
| All times are GMT -6. The time now is 05:15 AM. |
