dorman 49241 & 49242 switch wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2012, 06:55 PM
bought Dorman pwr window switches(chrome square) for my coupe project, 1 single button switch for the trunk (5 pin and 1 two button for the pwr windows). I bought AC Delco sockets and pigtails for the switches. Each pigtail has 12 ga. wires all the same color. I ohmed out the single switch and thought I had it correct but promptly fried both the switch and connector when I tried it.
Does anyone have a schematic showing the hot/ground/motor connections for the double (6 pin switch)? The pin orientation is:
O O O O
O O
The pin location looks correct as I type but when I preview the post the bottom 2 are out of position. The lower posts are direct below the corner posts on the top row.
The 4 pins on the top row all have continuity between them when the switch is in the normal (at rest) position.
Thanks
Bud
In case anyone needs them the ACD part #s for the pigtails are PT188 and PT 254.
Old 06-18-2012, 08:21 PM
EOD Guy's Avatar
Does it look like this?
Name:	dorman switch.jpg
Old 06-18-2012, 09:56 PM
yes,that looks like the same switch
Old 06-18-2012, 10:05 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The attached schematic should help when you OHM the switch.
vicrod
File Type: pdf forward reverse DC motor DPDT switch.pdf (196.2 KB, 700 views)
Old 06-18-2012, 11:30 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
#49241
#49242
I used 1983 Chevy C10 pu (which used these switches) as a basis, and found the wiring diagram for you ... see attached.
Name:	Power Window.gif
The Following User Says Thank You to 66GMC For This Useful Post:
rodder1234 (03-11-2015)
Old 06-19-2012, 06:05 PM
EOD Guy's Avatar
My translation of the wire dia
Name:	Pwr wind switch.jpg
Old 06-19-2012, 10:04 PM
Thanks for the schematics guys, VERY helpful
Bud
Old 08-26-2013, 06:53 PM
This thread has helped me enormously!
I'm attempting to modify my '63 Studebaker Avanti's power window system with newer and stronger motors for the 15lb windows. With newer, two wire motors, I had to get new switches and Dorman was clueless when I emailed them for a schematic.
Thanks so much, Guys! This info will really help.
Tom
Old 09-04-2013, 05:22 PM
Ugh.. not easy finding connectors to fit these Dorman switches. I assume there are multi-pin sockets that slip on them, but I'd like to find something to fit the pins individually. Any ideas? Thanks!
Old 03-11-2015, 08:20 PM
Power window switch
I also bought dorman 1 and 2 button switches 901-016 1nd 901-017 I am trying to wire the two windows with them. I can make the driver side work, both switches but can't get the passenger side to work with the single switch. I tried your diagram but the single switch will not work. What am I doing wrong?
Can you help?
Thanks my email is ynotte@gmail.com
Kill Switch/Wiring. HELP! 1976 K-5 Electrical 5 07-17-2010 02:49 PM
switch wiring notwired Electrical 1 10-23-2007 08:50 PM
headlight switch wiring cheech beach Electrical 5 09-03-2007 03:18 PM
#@%$ Dorman! machine shop tom Hotrodders' Lounge 12 03-07-2006 12:36 PM
ignition switch wiring daddyj Electrical 1 02-01-2003 02:19 PM
