Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dot 5 Silicone Brake Fluid?? Yes or No ??
Old 04-10-2002, 03:03 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Post
When I used DOT 5 it did not cause higher pedal pressure only a mushy feel because it is slightly more compressible than DOT 3 or 4. With the mechanical advantage at the pedal it becomes very noticeable.
Higher pedal pressure could be caused by the coagulation of DOT 3/4 and DOT 5 if the systems were no properly diassembled and cleaned with alcohol to remove the last traces of the incompatible fluid.
Despite what they teach you in school liquids are compressible, but the amount is miniscule compared to gases.
— Han Solo
