Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dot 5 Silicone Brake Fluid?? Yes or No ??
Old 04-13-2002, 05:01 AM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Post
On my home built Model A I used DOT 5 silicone brake fluid from the beginning. I have not had any problems with the braking system in the five years it has been on the road.
I am using a Mustang non-power master cylinder, GM front disc calipers with a Midland booster, GM drum rear, and have an adjustable proportioning valve in the rear line.
I will admit, it doesn't have the "throw you through the front windshield" feel that you get in a new car. Mostly because the Midland booster isn't doing much, running a prety high lift cam, there isn't much vacuum available.
