DOT3 vs DOT4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2012, 09:25 PM
mitmaks's Avatar
Last journal entry: Grille
DOT3 vs DOT4
My car manual calls for DOT3 brake fluid, would it be fine if I went with DOT4? All it does it increase boiling point?
Old 10-11-2012, 09:41 PM
Last journal entry: was hoping for better than this
dot 4 is synthetic
dot 3 isn't
they don't play nice together..
I'd stick with type 3
Old 10-11-2012, 09:43 PM
mitmaks's Avatar
Aren't you confusing DOT 4 and DOT5? I'm pretty sure I've read on label that you can intermix dot 3 and 4 but NOT DOT5
Old 10-11-2012, 09:54 PM
Dot 4 is ok
Dot 3, 4, & 5.1 are glycol base
Dot 5 is silicone base
don't mix the 2 base types together.
Old 10-11-2012, 10:35 PM
yup. my bad dot 5 is syn
