Double Cardan Joint - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2007, 09:14 PM
Double Cardan Joint
I am putting a 7 inch lift on my 1979 chevy 1/2 ton shortbox. I am wondering if I would be able to take a double cardan joint off a front driveshaft and put it on the rear driveshaft for more angle flexibility. Or any suggestions as to what I should do to my front and rear driveshafts to handle the angle of the 7 inch lift without spending a ton of money. THANKS
Old 09-10-2007, 09:29 PM
Crosley's Avatar
Wiki Edits: 1659
I've seen this used on 2WD trucks several times when the truck is lifted
Double u joint set up question artillerystevens Suspension - Brakes - Steering 12 01-14-2007 04:54 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Front Ball joint ... PICTURE bg Suspension - Brakes - Steering 17 04-16-2005 01:24 AM
Need help Identifying 327 & Double Hump Heads & Holly 63ChevyII Engine 9 09-07-2004 05:46 PM
double ujoint 36scsc Transmission - Rearend 4 01-27-2004 06:40 AM
