Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - double d shaft
Thread: double d shaft
Old 12-05-2012, 06:02 AM
JOHNSHENOUDA JOHNSHENOUDA is offline
double d shaft
I just put in my new steering column on my 30 model a. The column mounts to the floor. The end of the column, or the double D shaft, goes through the floor and is real close to the inside of the frame rail. I would say about 3/8". It turns freely now but if I put a coupling or a u joint on it it will scrape the frame. Can i just weld on a 6" piece of double D to the existing double D, or is that really unsafe? Any suggestions?
