Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - double d shaft
Thread: double d shaft
Old 12-05-2012, 10:03 AM
dinger's Avatar
dinger dinger is offline
How is the rest of the steering going to hook up to the steering box? Is it a direct shot to the box? Probably not, you may need a swivel or something else to make the final connections. I would hesitate to do any welding until you have all this figured out. You might have to squeeze another 1/4 inch or so of clearance and use a heim joint in there somewhere. Here's some photos and info from this site: Vega steering in a model a ford
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
