Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - double d shaft
Thread: double d shaft
Old 12-06-2012, 10:18 AM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
unless your a very good welder i would have a problem with you welding anything on your steering.
you'd be a lot better off and safer notching the frame to get your clearance or moving your column over half an inch to allow for a u-joint.
extending the dd shaft 6 inches out from the support bearing in the end of you column adds a lot of stress to the shaft, especially when you hit a pot hole.
i would not recommend welding an extension on the dd shaft.
