Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - double d shaft
Thread: double d shaft
Old 12-09-2012, 10:19 AM
prostcelica prostcelica is offline
Originally Posted by JOHNSHENOUDA View Post
I think the best thing to do is buy a 3/4 double d shaft. I think a solid 3/4 shaft will slide inside the 1" shaft nub that sticks out of the bottom of the column about 2". Once she is inside I can weld the "rim" of the two pieces together. At that point I imagine she should be like a rock.
Hey JOHNSHENOUDA. Welding on streering or braking components is always a little sketchy. (I also had to weld the steering shaft on my SBC celica). If you must do it the way you descibed is deffinatly the best way. Being that your going to slip it inside a piece of 1" and put a fillet weld on either side makes me feal better about it. Its a different story if you were going to bevel it and do butt joint. A but joint probobaly wouldnt let go but the way you purposed IS the best way. Just make sure your machine has enough jam.
Good luck
