Around 8.7:1 depending on gasket used and if your blocked been decked or not.
Thats 64cc heads, 30 over 283, 21 thou headgasket and 16 thou in the hole. Sell those heads on ebay for a couple hundred and buy some aftermarkets. Very cheap, a lot more power, and cooler. |
Shipping heads from Brazil to the states rules out eBay and of course importing heads from the states can be costly too. He probably will be happy with what he has.
Trees |
The humps will work great on your 283 actually a little to much head for that size engine.They will flow all that little puppy will need in fact they work well in a tunnel ram dual 4bbl in this case . any aftermarket head exept maybe a stock vortec would be overkill(runners way to big for the little small block).If you can get the fuel to support it flat mill em .040 and use a steel shim gasket ,do not increase the valve size. Also if you can find em a set of 305 heads 416 casting I think would also work very well on this engine. You need to think small cam and all.A cam advertised for 1500 to 4500 in a 350 might very well not start pulling till 3000 and stop at6500 in the "83.
Sounds like its going to be a fun engine, streetable, economic, and piece of history. I likey lets ee some pics. |
Do you know how to post pics here? Thanks. |
When you reply to a tread there is a manage attachments button. Click on it and it will brouse your computer for pictures, or you my have to select a pic. Click to edit the picture to make sure it is not too big. Resize it so it can fit the screen or pixle size. After saved exit the screen for editing and double click the new saved pic. It will save it to a separate miniscreen and then just click the upload button. Then submit a reply.
If you still have trouble there is a place on here with step by step instructions. Good luck. |
I took off the double humps. I bought a pair of newly rebuilt 283 power pack heads (9.25:1). The ones with a cast triangle atop of a cast rectangle. I've put a double hump side to side with a power pack and I could see how much bigger the DH combustion chambers are compared to the PP one. I guess that a 283 with dome pistons and double hump heads would make a nice engine...
| Camel Hump Heads on a 350 ? | chevy350_Camd | Engine | 42 | 02-17-2013 01:57 AM |
| help please!! double hump heads | DB fusmc | Engine | 10 | 06-17-2007 04:33 PM |
| What's so great about SBC double hump heads? | frankenvette | Engine | 3 | 07-24-2005 08:41 PM |
| 283 hump heads on 305 | blue85 | Engine | 1 | 11-17-2003 11:08 PM |
| camel hump heads | servant70131 | Hotrodders' Lounge | 2 | 10-17-2002 03:19 AM |
