double hump heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2008, 07:10 PM
chevy350cutlass's Avatar
double hump heads
have a set of 461 double hump heads all set to go for a 400 sb just wanted to know if they would be good for making 400hp. heres what i got block 406 with stock crank rods and flat top pistons cam Hydraulic Flat Tappet Advertised Duration 268/280 Lift .477/.480 heads have 2.02in 1.60ex screw in studs and guide plates with 64cc hoping for 9.5 to 1 c/r let me hear what you got to say Thanks
Old 11-01-2008, 10:42 PM
double hump heads
I agree with F-bird, besides, the newer inexpensive aftermarket iron heads have larger intake runners that will flow better with your cam selection.
Old 11-01-2008, 11:04 PM
what if i went with a stock like piston with a small dish and also the heads have been ported for a better flow with a bigger cam
Old 11-01-2008, 11:14 PM
ok ebay here i come thanks guys
Old 11-01-2008, 11:27 PM
double hump heads
You'll still have the inconvenience of no external bolt holes. A good runner for that cam would be 200 cc. Most early humps had 187cc runners with the major restriction located in the short turn area. These newer heads are cast better than the old heads can be ported.
Regarding the hard seat issue: If you use your heads, do not use the exhaust rotators and make sure your springs are correct and installed correctly. Re curving the distributor and making sure that your fuel system is jetted correctly will be adequate for a normal use street car - without hard seats.
However, if you plan on towing or extended severe duty, then hard seats are definitely needed - which increases the price comparative to the aftermarket ones.
Remember, your heads are probably more than 40 years old. That's a lot of stress cycles. The newer ones also have thicker decks to resist cracking.
Old 11-02-2008, 08:45 PM
461's will need the steam holes drilled for the 400 also.
Heads, not a fan of the sportsman II's, Dart Iron Eagle Platinums better imho.
For the record- the largest intake runner of any small block chevy production camel hump heads were 172cc 461X castings, most 462's, 461's, and 291's were 160cc-167cc. The largest SBC prodcution head runner is the LT4 195cc. Vortecs measure in at 170cc also.
To get 400hp out of a set of uported double humps on a 406 would take a lot of cam, even out of a 406.
Old 11-02-2008, 09:04 PM
what do you guys think about these heads Aluminum Strike Force 64cc heads you can look them up at performanceauto.us its a shop in town where i live
Old 11-03-2008, 01:31 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
And what I always find so interesting about these comparisons (kudos, genYnNc) is that the Vortecs with 2cc smaller runners outflow the 461s by almost 20%. That is HUGE. Add in the supremely efficient chambers and its a no-brainer.
Old 11-03-2008, 08:36 AM
lg1969's Avatar
Google "Tunnel Ram 406"
don't use those heads. If you do, You are going to need 110 octain gas for a 11.6:1 compression motor
http://www.csgnetwork.com/compcalc.html
Camel Hump Heads on a 350 ? chevy350_Camd Engine 38 02-17-2013 01:57 AM
help please!! double hump heads DB fusmc Engine 10 06-17-2007 04:33 PM
olds #5 head johann Engine 1 07-30-2006 10:05 PM
What's so great about SBC double hump heads? frankenvette Engine 3 07-24-2005 08:41 PM
small hump heads.. opeysgarage Engine 17 11-05-2003 08:05 PM
