We're winning the case!
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 06-22-2004, 11:13 PM
little racer's Avatar
little racer little racer is offline
Question double hump heads
Can I use double hump heads on a 400 sbc?
Old 06-23-2004, 05:06 AM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Yes, If you drill them for 400 steam holes.
Old 06-23-2004, 09:42 PM
tresi tresi is offline
Sure, you can drill the steam holes and it will run. If you want them to last you'll need to have hard seats installed and chrome stem or better valves for them to last with unleaded gas. It's a safe bet that they'll need new guides unless they've just been done. Throw in magnafluxing, tanking and surfacing and the by the time you've paid the machine shop you could have bought a set of Dart or World Products heads that are ready to go on unleaded and much less likely to crack.
Old 06-26-2004, 07:52 AM
machine shop tom machine shop tom is offline
Good advice from tresi.
Another thing to think about is compression. A lot of the double-hump heads with the 1.94" intake valves have chambers with 60cc volume or less. Makes for a LOT of compression with a flat-top pisotn. Make sure your combination figures in the chamber and have the heads cc'd to be sure.
tom
Old 06-26-2004, 07:14 PM
lluciano77's Avatar
lluciano77 lluciano77 is offline
Short changed on common sense
I always recommend aftermarket heads. It is not cost effective to run stockers. If you are going to use a stock head, go for the Vortec heads. You will need a Vortec style intake to match, but at least that combo would be worth it a little.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
