Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Double Hump or Vortec???
  #35 (permalink)
Old 01-16-2013, 04:24 PM
ap72 ap72 is offline
Banned
Originally Posted by hcompton View Post
Well if the cam is right it will run. Alum heads will make it possible but with anything careful tuning will be needed to make it run correctly on pump gas.
Comp 294s or bigger might be needed have to cc the heads and crunch the numbers. But it is Possible.
Pop ups are usally a little more detonation resistence. With a good squish band it should be ok. I think sunco 94 would be the most you would need with a proper tune.
87 octane is out of the questioon im sure.
pop up have less detonation resistance. And if you make it rich enough and pull out enough timing it'll run fine but it'll be down about 50hp. loading plays a big factor as well, a 4.56 rear in a light car like a pinto with a high stall and it'll be fine even with an optimal tune for power.
