I believe thats possible. I just don't understand why the dome pistons make it more difficult? If thats the case then why to race motors use dome top pistons? I understand things need to be matched properly but I don't understand why the domes seem to be killing me so bad???
The 64 cc heads can be a little less cc pretty easy just sink the valves down on into the seat a little further and smooth over all the sharp edges in the chanbers you will probably be at 65 66 cc a little mor etriming and you got 68 cc which should solve your issues.
If you buy new alum heads you will be able to request the chambers be worked over to any cc size you need. Best to buy ones that work. But in this case some triming may be in order done right it will also lessen the chance of detonation. |
I have an standard rpm intake to put on already. I actually had the center milled out like on the rpm air gap so I can take advantage of the extra 10hp and 15-20tq at the bottom of the curve that the rpm leaves on the table. Trust me, I want this to work!
FYI the Mustang dyno is the heart breaker dyno.The numbers from a mustang dyno will read lower than a Dyno-jet dyno. The Mustang dyno is easier to tune the engine as you can vary the load to the engine and keep the engine from running a higher RPM than you want. The Dyno-jet dyno is strictly inertia,there fore cannot hold a load on the engine,just measure the speed that the car accelerates on the roller.
Your torque being so much higher than your horse power(reguardless of gross numbers)indicates the camshaft and or heads are not enough for your engine. Typical of most v-8s. |
Ya Vin, i know all the sad mustang dyno stories lol. When I saw the tq number so much higher than the hp, I know it just wasn't breathing like it should be. So when selecting a cam, roller or flat tappet. Is there any benefit to having matched durations between the int/ex or stick with the splay of say the 225/230?
The extra duration on the exhaust side is usually to compensate for weak exhaust flow. If you heads flow 75-80% on the exhaust then single pattern is good(N.A.) turbos and blowers use different rules.There are exceptions to this rule as you will soon find out when others jump in and point out the times
So, as far as budget and power goes I'm thinking this cam with the pro-filer heads and my 1.6:1 SA roller rockers. Some make solid power through the band. Or I could go slightly farther up to this cam, which would move the power up slightly higher in the rpm. Or would a single pattern be ok for the pro-filer heads?
Pro-Filer 195cc 2.02"/1.60" .100" - 145/101 69.7% .200" - 205/144 70.2% .300" - 255/175 68.6% .400" - 278/194 69.8% .500" - 281/205 73% .600" - 282/213 75.5% .700" - 283/219 77.4% Data from http://users.erols.com/srweiss/tablehdc.htm Thoughts??? Last edited by Caballerokid; 01-16-2013 at 08:24 PM. |
You've gone from looking at $400 set of heads though to a $1100 set of heads and a $400+ cam kit... |
Ha, ya I know... but if it means quality and hp, its worth it. Also, the cam was always in the near future. I've been looking at the SHP heads for awhile too. So not too far off from what I was really thinking it would cost. I was just hoping to come in under the wire with a decent set of vortecs. Thats why I asked lots of questions. I like to know all my options on the table and then make an educated decision. 10 years ago, I was still getting my feet wet. I have learned a lot since then! Thank you guys for all your help!
Its one of those "pay now, or pay more later" deals. |
I understand. Im actually really excited about the Pro-Filer heads. They flow CRAZY for the price and as much competition as there is in the sbc cyl head market. Matching those with a powerful roller cam im very optimistic of the power that can be made. Thanks for all the advice and options you guys gave me.
| Double hump heads | Luiz | Engine | 16 | 07-21-2008 05:27 AM |
| double hump heads | little racer | Hotrodding Basics | 4 | 06-26-2004 07:14 PM |
| camel hump or double hump | cheezbay | Engine | 3 | 03-25-2004 10:22 AM |
| 2.02 double hump heads | 73monte | Engine | 3 | 11-28-2003 12:32 PM |
| old double hump heads | chale24088 | Engine | 8 | 06-20-2002 12:37 PM |
