Double Pole Park Lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2003, 06:36 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
I bought a pair of 1953 Chevy truck park lights to use as backup lights on my 54 truck. These park lights are double-pole, intended to be used as park lights and turn signals ... I wired 'em up to a toggle switch and when I turn 'em on, they light up only one filament (park). There are just 2 wires -- black & green -- I wired black to ground and green to hot.
My Q is, how can I wire 'em up so BOTH filaments light up when I throw my switch, giving me a nice bright backup light?
Alan
54 Chevy Pickup
Old 08-14-2003, 06:47 PM
hiimed's Avatar
Truck - '49...Driver - '47
Alan-
I would say that the housing is the ground. Try wiring both green and black wires to the backup light and be sure that the light is grounded. That's the way my tail lights are: one wire for light and one wire for brake.
Old 08-14-2003, 06:51 PM
horvath's Avatar
Thanks, man.
I was just thinking ... my toggle switch provides the ground, so maybe I should wire both wires to hot - 2 filaments; 2 wires ... but I needed some confirmation.
Alan
54 Chevy Pickup
Old 08-14-2003, 07:03 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Hiimed, is right the housing has to have a good ground.
A ground at the switch will not effect the light housing itself.
Troy
Old 08-14-2003, 07:13 PM
horvath's Avatar
So, tomorrow I'll run a ground wire to the housing, run both wires to hot, and see.
Thanks, Troy!
Alan
54 Chevy Pickup
Old 08-14-2003, 09:05 PM
troy-curt's Avatar
The way the lights are mounted they should be grounded, check it with a test light.
Troy
