Double Steering U-joints? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2013, 12:23 AM
Elevinpointsixtoone's Avatar
Hey help me out on this one: Stub column with double u-joint on output shaft, drops through firewall supported with support bearing mounted to firewall, another double u-joint to get the DD shaft aimed at the gear box, box has a single u-joint. This is all theoretical but pretty much what needs to be assembled. Where should I put another support bearing? Right after the 2nd double u-joint near the outside of firewall or down stream closer to the gear box? Mid ship? I dunno....
2nd question...do you need to "phase" a pair of double u-joints?
Thanks,
Dave
Old 05-16-2013, 10:54 AM
sedanbob's Avatar
Here is the Borgeson catalog - pages 25-29 give all sorts of info on steering design... http://www.borgeson.com/Images/2013_Catalog.pdf
Old 05-17-2013, 12:26 AM
well that pretty much answers all my questions...Thanks!
Old 05-17-2013, 12:58 PM
sedanbob's Avatar
That's one of the things I looked at when I designed mine - worked for me. Glad it works for you.
Low priced steering U-joints from Ebay? staleg Suspension - Brakes - Steering 5 10-06-2010 10:08 AM
Steering U joints 31chevy Suspension - Brakes - Steering 2 09-13-2008 04:27 PM
who needs those HIGH $$$ steering joints, not me! ! ! TooMany2count Suspension - Brakes - Steering 22 03-08-2007 11:06 AM
Where to buy steering u-joints cornfieldcars Suspension - Brakes - Steering 11 10-20-2006 11:31 AM
universal steering shaft joints 49dream Suspension - Brakes - Steering 1 03-15-2006 07:09 PM
