Double Trouble; Twin engines - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2014, 05:10 PM
hduff's Avatar
Fix it until it breaks
Last journal entry: Clutter
This is a pic of "Double Trouble"
While I can see some detail in the pics from that page, I have some questions.
How does one connect two engines to the driveline? How do you synchronize them?
I'm just curious. Any links for a HOWTO or discussion?
Old 03-26-2014, 06:37 PM
ericnova72's Avatar
More for Less Racer
It's in the specs listed at the bottom of the linked page, a 90MM wide toothed Gilmer belt(like a big 6-71 blower belt) connects the two cranks to a central custom jackshaft that drives an ordinary Ford C-5 trans Drive is enclosed in a custom bellhousing fabbed by the owner, looks like made of aluminum plate to me .
Builder says the think of a large triangle for belt routing.
Fun to look at but I bet it isn't as fast as you might think.
Saw this driving on Counting Cars on the TV.
The Following User Says Thank You to ericnova72 For This Useful Post:
hduff (03-26-2014)
Old 03-26-2014, 06:46 PM
poncho62's Avatar
Wiki Edits: 5
Wonder if it has power steering?....would be a bear to steer without it
Old 03-26-2014, 09:16 PM
hduff's Avatar
Originally Posted by ericnova72 View Post
It's in the specs listed at the bottom of the linked page, .
I didn't read it that way at first, but I see it now.
Anybody familiar with other cars set up this way? My Google-fu is not helpng met out this time.
Old 03-26-2014, 09:18 PM
hduff's Avatar
Really. That's a lot of weight over the front axle.
Old 03-26-2014, 09:23 PM
hduff's Avatar
Anybody see any in-line V-8s?
I did find this: Twin Engine Coupling (How Do You Get Two V8's In-Line?) - Page 2 - THE H.A.M.B.
Old 03-26-2014, 09:40 PM
ericnova72's Avatar
More for Less Racer
Originally Posted by hduff View Post
Lots of them if you look into early 1960's Dragsters. TV Tommy Ivo, Eddie Hill, John Peters "The Freight Train", Mickey Thompson, Howard's Cam Bear are just a few that come to mind. Examples of both inline and side-by-side.
A friend of mine built a Gilmer belt drive reduction box out of aluminum plate onto the block flange of a 350 Chevy...To slow rpm to correct speed for a 5' Laminated Wood Airplane prop when he built has own swamp Airboat. Machined his own Gilmer pulleys for it also
Old 03-29-2014, 11:56 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
https://www.youtube.com/watch?v=pfVYq7SUqpw
Jester
The Following User Says Thank You to painted jester For This Useful Post:
hduff (04-01-2014)
Old 03-29-2014, 12:39 PM
We used inclosed gear & quad-row chain drive from engine crank to crank and electric Motor couplings to differential instead of universals because of the massive torque! And a variable speed drive and forget about your old car trannies !!
The thing that suprises me is the little single V belts on each blower ? And HOW DOES HE SEE PAST THE ENGINES TO DRIVE ON THE STREET???? I get a ticket because of my fuzzy dice and baby shoes on my mirror !!!!!!
Jester
https://www.youtube.com/watch?v=UexiOL8I_3Y
hduff (04-01-2014)
Old 03-29-2014, 12:49 PM
ogre's Avatar
the 'Duracell Project'
i'd rather start with a factory twin six
this would be cool under the hood of my 59 panel truck
Old 03-29-2014, 03:30 PM
Double trouble is a beautiful piece of engineering, but it not really a rod for the average guys street ride! I certainly like that GMC V12. Question is where can I get one. When I started building I was looking for something different, not the usual V8s you see so often. I prowled the wrecking yards in southern Ontario Canada and contacted yards in the North eastern US for one of GMC's BIG sixes, a 427 or 503 with no luck. had to settle for a 292 Chev. Looks and sounds good. Also looked for one of the V16 Cadillacs. One of the yards had one but it was well beyond restoration. I like unusual and Double Trouble is beautiful, no doubt.
Old 04-01-2014, 07:03 PM
We can do that
A lot of good pix and info here: TwoToGo Twin Engine Drag Car History
The Following User Says Thank You to Dragonoake For This Useful Post:
hduff (04-01-2014)
Old 04-01-2014, 07:10 PM
Tommy Ivo did both ....
In the same car
Tommy Ivo's Buick 4 Engine, 4 Wheel Drive Dragster!!!
hduff (04-01-2014)
Old 04-01-2014, 07:38 PM
I lost the link when I re-installed windows a while back, but there is a place that builds hot rod Jimmy V-12s
Old 04-01-2014, 08:33 PM
ogre's Avatar
i just googled hot rod gmc V-12s amazing the amount of hot rods with gmc v12s in them
some are true hot rods, some belong in the come on man thread
you choose
Twin Turbo's srwilson8074 Engine 11 02-02-2012 12:45 PM
twin-engined Nightrider Engine 1 09-01-2006 02:59 AM
Double Trouble 67 Mustang To Muscle exiled1 Hotrodding Basics 5 10-28-2005 08:38 AM
Twin I Beams SMF Speed&Custom Suspension - Brakes - Steering 3 06-09-2005 02:18 PM
twin V8 in a hotrod 8BA371 Engine 2 11-22-2002 06:43 AM
