Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Double U joint question
Old 11-22-2012, 05:09 AM
sunsetdart sunsetdart is offline
Last journal entry: 50 Ply wagon
Using a double U joint connection is the best way to offset the shaft. The support bearing must be placed correctly and allow the shaft to spin freely.
A double U joint for steering is no different than the double U joints used in many 4 wheel drive applications.
Use Borgeson steering joints as well.....they are the best out there.
