Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Double U joint question
Old 11-22-2012, 08:51 PM
John long John long is offline
I am using a double u-joint exactly as you are describing but do not have as severe of an angle. Mine works fine.
Woodward also makes a good double joint that comes in all different lengths between the joints which may allow you to keep the angles to a minimum.
