Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Double u joint set up question
Old 01-08-2007, 03:17 PM
Centerline Centerline is offline
Wiki Edits: 49
Originally Posted by OKSoda
You might need a heim.
No "MIGHT" about it! If you are using two "U" joints you will have to have a support otherwise it will bind. In other words, if you're using one "U" joint on the steering column and one on the steering box... you won't need a center support, but if you have a "U" joint in between the two you will have to use a heim support to keep it from binding.
